ZUKIWORLD online’s
TABLE AND INFORMATION INCOMPLETE.
2009 SUZUKI EQUATOR – TECHNICAL SPECIFICATIONS
Body Type Extended Cab Crew Cab Engine I4 V6 V6 Drive System 2WD 4WD 2WD 4WD Transmission MT AT AT AT AT AT AT Grade BASE PREMIUM SPORT BASE SPORT SPORT RMZ-4 Engine Code QR25 VQ40 Engine Type 2.5 l DOHC I4 4.0 l DOHS V6 Max HP 152 @ 5,200 261 @ 5,600 Max TQ 171 @ 4,400 281 @ 4,000
2009 SUZUKI EQUATOR – TECHNICAL SPECIFICATIONS Body type Extended Cab Crew Cab Engine I4 V6 V6 Drive system 2WD 2WD 4WD Transmission MT AT AT Grade Base Premium Sport Base Sport Sport RMZ TRANSMISSION AND DRIVE SYSTEM Drive configuration Two-wheel drive Two-wheel drive Four-wheel drive Transmission type Five-speed manual S – – – – – – Five-speed automatic w/overdrive – S S S S S S Gear ratios (:1) 1st 3.58 3.842 2nd 2.077 2.353 3rd 1.360 1.529 4th 1.000 1.000 5th 0.811 0.839 Reverse 3.636 2.764 Final drive ratio 4.083 3.916 3.133 3.133 3.133 3.357 3.357 Rear axle Dana 44 – – – – – – S C200 S S S S S S – Transfer case Rotary switch for part-time 4WD – – – – – S S Transfer case ratio Four-wheel drive low – – – – – 2.625 2.625 Crawl ratio 1st gear AT – – – – – 33.86 33.86 Electric rear locking differential 4X4 – – – – – – S CHASSIS Chassis Type Body on frame (ladder type) – Fully boxed frame Primary materials Corrosion resistant, high strength steel Steering Type Rack-and-pinion Power assisted Engine speed sensitive Overall ratio 20.4:1 Turns (lock to lock) 3.55 turns Turning radius (curb to curb) ft./m 21.75/6.62 21.75/6.64 21.75/6.64 21.67/6.60 Turning circle (curb to curb) ft./m 43.42/13.2 43.58/13.3 43.58/13.3 43.33/13.2 Suspension – Front Independent S – Bilstein high performance shocks – S Stabilizer bar S Suspension – Rear Overslung multi-Leaf S Bilstein high-performance shocks – S Stabilizer bar n/a Brakes – Front Two piston calipers S Vented discs S Disc size (diameter x thickness) mm 283 x 18 296 x 28 Brakes – Rear Single piston calipers S Vented discs S Disc size (diameter x thickness) mm 286 x 18 Pitch Circle Diameter (PCD) 6 in. x 4.5 in. (6 in. x 114.3 mm) Tires P235/75R15 General Grabber AW (black letter) S – – – – – – P265/70R16 BFG Long Trail (OWL) – S – S – – – P265/65R17 BFG Long Trail (OWL) – – S – S S – P265/75R16 BFG Rugged Trail (OWL) – – – – – – S Spare tire Conventional S Electrical Ignition system Type Electronic (direct ignition) Starter Rating 12 volt Alternator 12 volts 110 amps Battery GR24F-550 EXTERIOR DIMENSIONS Overall length Short bed in. (mm) 206.6 (5,258) 206.6 (5,258) – 206.6 (5,258) Long bed in. (mm) – 220.1 (5,612) 220.1 (5,612) – Overall width in. (mm) 72.8 (1,850) Overall height in. (mm) 68.7 (1,745) 69.7 (1,770) 70.1 (1,780) Wheelbase Short bed in. (mm) 125.9 (3,200) 125.9 (3,200) 125.9 (3,200) Long bed in. (mm) – 139.9 (3,554) 139.9 (3,554) – Ground clearance At rear differential in. (mm) 8.7 (221.4) 9.8 (248.4) 9.8 (248.4) 9.8 (248.4) 10.1 (257.4) 10.1 (257.4) At front differential in. (mm) n/a n/a n/a n/a 8.9 (226.1) 8.9 (226.1) Minimum running in. (mm) 7.6 (193.4) 8.6 (218.2) 8.6 (218.2) 8.6 (218.2) 8.9 (226.1) 8.9 (226.1) Overhang Front in. (mm) 31.3 (795) Rear in. (mm) 48.2 (1,225) Track width Front in. (mm) 61.8 (1,570) Rear in. (mm) 61.8 (1,570) Approach angle degrees 27.8 30.5 30.5 30.5 31.5 32.6 Departure angle degrees 21.0 22.1 22.1 22.1 22.6 23.3 Break over angle degrees 18.0 19.8 19.8 19.8 20.6 20.5 Bed length Short bed in. (mm) 73.3 (1,861.3) 59.5 (1,511.3) 59.5 (1,511.3) 59.5 (1,511.3) Long bed in. (mm) 73.3 (1,861.3) 73.3 (1,861.3) Bed width At tailgate in. (mm) 58.8 (1,494) At C-channel in. (mm) 61.4 (1,560) Between wheel wells in. (mm) 44.4 (1,130) Bed depth in. (mm) 18.0 (457.3) Bed cargo volume Short bed cu. ft. 33.5 27.1 27.1 – 27.1 Long bed cu. ft. 33.5 33.5 Step-in height First row in. (mm) 19.9 (505.1) 19.8 (504.1) Second row in. (mm) 21.9 (555) 20.6 (523.6) Hip point to outer sill (first row) in. (mm) 16.8 (426) 16.8 (426) INTERIOR DIMENSIONS First row Head room in. (mm) 39.7 (1,009.6) 40.0 (1,016.7) Shoulder room in. (mm) 58.3 (1,480.5) 58.3 (1,480.5) Hip room in. (mm) 55.8 (1,416.2) 55.6 (1,411.6) Leg room in. (mm) 42.4 (1,076.4) 42.4 (1,076.4) Second row Head room in. (mm) 38.3 (972.9) 38.7 (982.5) Shoulder room in. (mm) 54.9 (1,394.5) 58.3 (1,480.8) Hip room in. (mm) 55.0 (1,395.8) 58.0 (1,472.8) Leg room in. (mm) 25.4 (644.1) 33.6 (854) Interior volume First row cu. ft. 56.8 57.2 Second row cu. ft. 30.9 38.8 Total volume cu. ft. 87.7 101.1 CAPACITIES Fuel tank L/gal 80/21.1 Engine oil L/qt 4.26/4.50 5.08/5.37 Engine coolant L/qt 9.4/9.3 10.2/10.8 Washer fluid L/qt 4.5/4.7 WEIGHTS Base curb weight MT lbs (kg) 3,686 (1,673) – – – – – – AT lbs (kg) – 3,801 (1,725) 4,125 (1,872) 4,248 (1,927) 4,248 (1,927) 4,430 (2,010) 4,491 (2,38) AT long bed lbs (kg) – – – 4,303 (1,952) 4,303 (1,952) 4,518 (2,050) Weight distribution (front/rear) MT % 54/46 – – – – – – AT % 55/45 57/43 55/45 55/45 57/43 57/43 AT long bed % – – – 54/46 54/46 56/44 – GAWR front lbs (kg) 2,531 (1,148) 3,296 (1,495) rear lbs (kg) 2,531 (1,148) 3,330 (1,511) GCWR lbs (kg) 7,936 (3,600) 11,133 (5,050) GVWR MT lbs (kg) 4,690 (2,132) – – – – – – AT lbs (kg) – 4,690 (2,132) 5,577 (2,535) 5,730 (2,599) 5,730 (2,599) 5,816 (2,638) 5,600 (2,540) Max payload MT lbs (kg) 986 (448) – – – – – – AT lbs (kg) 883 (402) 1,461 (664) 1,471 (669) 1,471 (669) 1,382 (628) 1,105 (502) AT long bed lbs (kg) – – – 1,423 (647) 1,423 (647) 1,293 (588) Load rating Utility cleat (where applicable) lbs (kg) 200 (91) TOWING Maximum capacity lbs (kg) 3,500 (1,588) 6,500 (2,949) 6,300 (2,858) 6,300 (2,858) 61,00 (2,767) Tongue load lbs (kg) 350 (158) 650 (295) 630 (295) 630 (295) 610 (277) FUEL CONSUMPTION M/T City/highway mpg 19/23 – – A/T City/highway mpg – 17/22 15/20
