ZUKIWORLD online’s
Grand Vitara J3-Introduced in 2006 designated by 4 doors, unibody construction, and a longitudinal mounted drivetrain with V6 engine.
ENGINE
Type: 2.7-liter, V6, 24-valve DOHC
Materials: Aluminum cylinder block/aluminum cylinder heads
Displacement: 2.7 liters (2,736 cc/167 cu. in.)
Bore x stroke: 88.0 mm x 75.0 mm/3.46 in. x 2.95 in.
Compression ratio: 9.5:1
Horsepower: 185 hp @ 6,000 RPM
Torque: 184 lb.-ft. @ 4,500 RPM
Valves per cylinder: Four
Fuel system: Electronic multi-port fuel injection, variable induction system, in-tank fuel pump
Emission compliance: LEV II/BIN5
Exhaust: Single
TRANSMISSIONS
Five-speed manual
1st 4.550:1
2nd 2.357:1
3rd 1.695:1
4th 1.242:1
5th 1.000:1
Reverse 4.436:1
Final drive ratio 3.583:1
Five-speed automatic
1st 3.520:1
2nd 2.043:1
3rd 1.401:1
4th 1.000:1
5th 0.717:1
Reverse 3.224:1
Final drive ratio 4.300:1
FOUR-WHEEL-DRIVE SYSTEMS
Four-Mode full-time four-wheel drive: all-wheel-drive system and two speed transfer case with locking differential and low range gearing. The operating modes are: 4H mode, 4H lock mode, 4L lock mode (differential is always locked in 4L) and neutral mode for flat towing.
SUSPENSION
Front: Independent: MacPherson strut suspension with coil springs, hydraulic shock absorbers and anti-roll bar.
Rear: Independent: Multi-link suspension with coil springs, hydraulic shock absorbers and anti-roll bar.
STEERING
Type: Power-assisted rack-and-pinion
Overall ratio: 14.0:1
Turns, lock-to-lock: 2.7
Turning circle: 36.7 ft. (11.2 meters) curb-to-curb
BRAKES
Front: Power-assisted vented disc with floating two-piston calipers and pad wear sensor
Rear: Power-assisted rear drum (10.0 in./254 mm)
ABS: Standard, four wheel, four channel
Traction control: Standard
Electronic Stability
Program (ESP)1: Standard
WHEELS 16 x 6.5-in. steel
16 x 6.5-in. alloy
17 x 6.5-in. alloy
TIRES P225/70R16
P225/65R17
Spare: P225/70R16
EXTERIOR DIMENSIONS
Wheelbase: 103.9 in. (2,640 mm)
Overall length: 176.0 in. (4,470 mm)
Overall width: 71.3 in. (1,810 mm)
Overall height: 66.7 in. (1,695 mm) 4WD/66.3 in. (1,683 mm) 2WD
Tread width, f/r: 60.6 in. (1,540 mm)/61.4 in. (1,560 mm)
Overhang, front: 29.7 in. (755 mm)
Overhang, rear: 42.3 in. (1,075 mm)
Ground clearance: 7.9 in. (200 mm) 4WD/7.4 in. (188 mm) 2WD
Approach angle: 29 degrees 4WD/28 degrees 2WD
Departure angle: 26 degrees 4WD/25 degrees 2WD
Ramp break over angle: 19 degrees 4WD/18 degrees 2WD
INTERIOR DIMENSIONS
Headroom
Front: 40.0 in. (1,016 mm)/38.2 in. (971 mm) with sunroof
Rear: 38.2 in. (970 mm)
Legroom
Front: 41.3 in. (1,050 mm)
Rear: 37.2 in. (945 mm)
Shoulder room
Front: 56.3 in. (1,413 mm)
Rear: 54.9 in. (1,394 mm)
Hip Room
Front: 55.5 in. (1,409 mm)
Rear: 44.0 in. (1,119 mm)
Interior volume: 125.4 cu. ft./122.9 cu. ft. with sunroof
SAE cargo index: 24.4 cu. ft. (rear seat up)/68.9 cu. ft. (rear seat down)
23.8 cu. ft. (rear seat up)/67.3 cu. ft. (rear seat down) with sunroof
CAPACITIES
Fuel tank: 17.4 gallons (66 liters)
Engine oil: 5.0 quarts (4.8 liters) with filter
Engine coolant: 8.6 quarts (8.2 liters)
CURB WEIGHT
RWD, manual transmission: 3,452 lbs. (1,566 kg)
RWD, auto transmission: 3,505 lbs. (1,590 kg)
4WD, manual transmission: 3,582 lbs. (1,625 kg)
4WD, auto transmission: 3,682 lbs. (1,670 kg)
TOWING
RWD, manual transmission: 3,000 lbs. (1,360.7 kg)
RWD, auto transmission: 3,000 lbs. (1,360.7 kg)
4WD, manual transmission: 3,000 lbs. (1,360.7 kg)
4WD, auto transmission: 3,000 lbs. (1,360.7 kg)
EPA FUEL ECONOMY ESTIMATES
Manual transmission: 18 mpg/city and 23 mpg/highway
Automatic transmission:
2WD: 19 mpg/city and 24 mpg/highway
4WD: 19 mpg/city and 23 mpg/highway
Are the manual gearboxes in the 2006 grand vitara 4 cylinder and the v6 the same? If not what gearbox do I need for my v6? (Part number)
