XL-7 2nd Gen. Vehicle Specifications
ZUKIWORLD online’s
XL-7 Gen 2 -Introduced in 2007 designated by 4 doors, and a larger capacity from a Grand Vitara. Upgraded trim packages, transverse mounted V6 engine, Unibody design.
ENGINE
Type:                                       3.6-liter, V6, 24-valve DOHC (Suzuki N36A)
Materials:                                Aluminum cylinder block/aluminum cylinder heads
Displacement:                         3.6 liters (3,564 cc/217 cu. in.)
Bore x stroke:                          94.0 mm x 85.6 mm/3.70 in. x 3.37 in.
Compression ratio:                10.2:1
Horsepower:                           252 hp @ 6,500 RPM
Torque:                                    243 lb.-ft. @ 2,300 RPM
Valves per cylinder:                       Four
Fuel system:                            Electronic multi-port fuel injection, variable induction system, in-tank fuel pump
Emission compliance:            Dual, close-coupled catalytic converters, positive crankcase ventilation, intake and exhaust cam phasers with internal exhaust gas recirculation and evaporative emissions system
Exhaust:                                  Dual, stainless steel
TRANSMISSION
Five-speed automatic (AF33-5 Aisin AW) with manumatic control
1st                                            4.68:1
2nd                                           2.94:1
3rd                                            1.92:1
4th                                            1.30:1
5th                                            1.00:1
Reverse                                   3.18:1
Final drive ratio                 2.48:1
ALL-WHEEL-DRIVE SYSTEM
Electronically controlled, on-demand all-wheel drive.  PTO on transaxle with rear-mounted electronic clutch pack delivers torque to rear wheels as necessary.
SUSPENSION
Front:                                       Independent:  MacPherson strut suspension with coil springs, hydraulic shock absorbers and 26 mm anti-roll bar.
Rear:                                       Independent:  Multi-link (four link) suspension with coil springs, hydraulic shock absorbers and 20 mm anti-roll bar.  Seven-passenger versions are fitted with Nivomat load-leveling shock absorbers.
STEERING
Type:                                       Hydraulic, power-assisted, fixed-ratio rack-and-pinion
Overall ratio:                            17.1:1
Turns, lock-to-lock:            2.7
Turning circle:                          41.8 ft. (12.7 meters) curb-to-curb
BRAKES
Front:                                       Power-assisted vented disc (11.6 in./296 mm) with floating two-piston calipers and pad wear sensors
Rear:                                       Power-assisted disc (11.6 in./296 mm) with single piston calipers
ABS:                                        Standard, four-wheel, four-channel with electronic brake-force distribution (EBD)
Traction control:                        Standard, engine torque reduction
Electronic Stability
Program (ESP)1
(including traction control):             Standard
WHEELS                                16 x 6.5-in. alloy
                                                17 x 7.0-in. alloy
                                                17 x 7.0-in. chrome plated alloy (Platinum Touring Package)
TIRES                                     P235/65R16
                                                P235/60R17
Spare:                                     Full-size spare
EXTERIOR DIMENSIONS
Wheelbase:                             112.4 in. (2,857 mm)
Overall length:                          197.2 in. (5,008 mm)
Overall width:                           72.2 in. (1,835 mm)
Overall height:                         68.9 in. (1,750 mm)
Tread width, f/r:                    61.6 in. (1,565 mm)/61.8 in. (1,570 mm)
Overhang, front:                37.5 in. (953 mm)
Overhang, rear:                 46.5 in. (1,181 mm)
Ground clearance:                    7.9 in. (200.6 mm)
Approach angle:               17.5 degrees
Departure angle:               20.0 degrees
INTERIOR DIMENSIONS
Headroom
Front:                           41.3 in. (1,048 mm)
            Rear:                           40.0 in. (1,015 mm)
            Third:                           38.8 in. (986 mm)
Legroom
            Front:                           41.2 in. (1,047 mm)
            Rear:                           38.8 in. (986 mm)
            Third:                           30.9 in. (784 mm)
Shoulder room
            Front:                           55.6 in. (1,413 mm)
            Rear:                           55.3 in. (1,405 mm)
            Third:                           50.0 in. (1,270 mm)
Hip Room
            Front:                           52.2 in. (1,325 mm)
            Rear:                           53.1 in. (1,350 mm)
            Third:                           38.2 in. (971 mm)
Total interior volume:                        146.1 cu. ft.
Passenger volume:                        132.1 cu. ft.
Maximum cargo volume:             14.0 cu. ft. (all seats up)/ 49.4 cu. ft. (behind 2nd row)/ 95.2 cu. ft. (behind 1st row)
CAPACITIES
Fuel tank:                                 18.6 gallons (70.3 liters)
Engine oil:                               5.0 quarts (4.8 liters) with filter
Engine coolant:            12.7 quarts (12.0 liters) – two-row configuration
                                                13.1 quarts (12.4 liters) – three-row configuration
CURB WEIGHT
2WD, auto transmission:            3,886 lbs. (1,763 kg)
AWD, auto transmission:            4,049 lbs. (1,837 kg)
Weight dist, f/r:                    57 percent/43 percent
Payload:                                  1,127 lbs. (511 kg)
TOWING
2WD, auto transmission:            3,500 lbs. (1,587 kg)
AWD, auto transmission:            3,500 lbs. (1,587 kg)
EPA FUEL ECONOMY ESTIMATES
2WD, auto transmission:            18 mpg/city and 24 mpg/highway
AWD, auto transmission:            17 mpg/city and 23 mpg/highway
Check Also
Jarbidge Nevada – An oasis
JARBIDGE, NV - Several years ago, on one of our epic ZUKIWORLD adventures, long before the term "overland" was really anything other than the word after "Willys" we were on a journey along the northern edge of Nevada exploring ghost towns and abandoned mines.
Leave a Reply
Your email address will not be published. Required fields are marked *
This site uses Akismet to reduce spam. Learn how your comment data is processed.
