ZUKIWORLD Review: Shifter Pin Upgrade – Installation of a New Shift Pin Fix Kit
HAWK’s Shifter Pin Upgrade
Installation of Hawk Strictly Suzuki’s New Shift Pin Fix Kit.
Editor/Photo: Eric Bewley
CORVALLIS, OR -Every Samurai I have owned so far has had this exact same problem. The shifter is so loose one can never tell what gear they are in. Is it first? Third? Fifth? It all boils down to a simple two-dollar part that keeps all of the bits working as intended. The problem is that even after you ‘fix’ the transmission shifting with that bolt, it is only a matter of time before your back in there again changing another broken shift pin. Suzuki knew this was a problem also and came up with a fix on their late model Samurai transmission. Unfortunately, most people have the early model. Hawk has come up with a quick and easy swap that puts the larger factory pin on your early model transmission. We installed this kit in little more than a half hour and were extremely impressed with the results.
click to enlarge
1. The kit as shipped from Hawk Strictly Suzuki. NOTE the larger pin installed in the shift tower.
click to enlarge
2. Remove the shift knob, outer boot, inner boot, and the three bolts that hold on the retaining ring.
3. Remove shifter
click to enlarge
4. Salvaged these three pieces off of your old shifter.
click to enlarge
5. Re-assemble on your new shifter.
click to enlarge
6. Remove old shift tower and clean the surface.
click to enlarge
7. Note the broken smaller pin on our old tower.
click to enlarge
8. Apply gasket material on new shift tower and install.
click to enlarge
9. Install new shifter, bolt down retaining ring taking care to get the thrust washer and poly boot lined up to each other.
click to enlarge
10. Install your shift knob and enjoy tight shifting again.
This kit is available from Hawk Strictly Suzuki 1(888)SAMURAI for $59.99 with a $25 core for the shifter and $25 core for the shift tower. We were very impressed with the completeness and quality of this kit and would recommend you call them today to kiss your shifting blues away.
Check Also
ZUKIWORLD Fall Classic explores the Ochoco National Forest
PRINEVILLE, OR – We have been holding the Fall Classic adventure event for over 20+ …
4 comments
  1. Hello – will this kit work for a suzuki hatch alto (1983)
  2. I need a shift pin, shift tower kit for a 1999 Suzuki vitara.
  3. where can i purchase this shifter tower? From what I can tell Hawk Strictly Suzuki isn’t in business. I thought Low Range Off-road may have bought them out but I don’t see the tower on their site either.
Leave a Reply
Your email address will not be published. Required fields are marked *
This site uses Akismet to reduce spam. Learn how your comment data is processed.
