Installing a Trailer Hitch Receiver to a Suzuki Sidekick / Geo Tracker
Hitchin’ to a Sidekick. -Junior
RENTON, WA Dont blink, or youll miss our six and half-minute installation of Draw-Tites trailer tow hitch. No kidding, this install took more time to brief the instructions then it did to install the hitch. (Hitch courtesy of Calmini Products Inc.)
First and foremost we determined the size and weight of our trailer we intended to tow before we acquired the hitch. Working with the load limits of the vehicle, ours is a 4-door SideKick, with a max tow capacity of around 1500 lbs, wed be looking for a smaller utility or camping trailer. Considering some serious yard-work was in our future we specd a small utility trailer to haul supplies and materials. And once the yard was completed, and passed a spouses approval test, it was be time to hook up the sailboat and take in some sailing.
After confirming the max capacity of the hitch itself at 2000 lbs, and locating the required 2″ ball our trailer required, it was time to complete the project. Beginning with the instruction we collected the required tools. In the case of the SideKick just a 19mm, or a 3/4inch, wrench would be required to mount it, then a torque wrench to torque the bolts to their required 68 foot pounds. (note; for X90 applications four 7/16 X 1 X 2 blocks will be required as shims between the frame and the hitch. This is for clearance issues)
This Sidekick easily handles a utility trailer.
Not all SideKicks came with a rear impact bar, but if one is present remove it. Keep it around in the event the hitch is ever removed. This devise aids the frame integrity if a rear impact should occur. The hitch does the same thing. Next we simply held the hitch in place, lining up the four slots on the hitch with the existing welded nuts within the frame of the vehicle, and tightened the bolds. Before torqueing we confirmed clearance with fuel cell and rear decorative valance, then completed the install by placing the 68 foot pounds of torque to all four bolts.
Finally we installed the supplied draw-bar or receiver, the pin and clip, and we were complete. The hitch has a clean and sturdy look to it and it should provide years of valuable service.
Other considerations are; wiring for lights, brakes if required, and safety chain. The Draw-Tite hitch has a max gross trailer weight rating of 2000 lbs and a max tongue weight of 200 lbs. This product only adds 15.5 pounds additional weight to the vehicle.
Consult with your local Suzuki dealer or check in the vehicles owner manual for exact towing specifications and limitations.
I bought the Curt trailer hitch from Uhaul for my 1993 Suzuki sidekick and went to install it yesterday and I can not get the bolts to screw into the welded nuts within the frame. I must have sat there for 30 minutes trying to screw the bolt in but no avail.
Any ideas anyone?
Great job explaining really appreciate it.
