Suzuki: Diagnostic Trouble Codes
86–95 Samurai / Swift  / 89 Sidekick
NOTE: This information does not apply to carbureted engines, as they will not have a check engine light and no codes are retrievable. DTCs may be accessed by installing a spare fuse into the fuse box diagnostic terminal, located under the LH side of the instrument panel, then turning the ignition On.
90–95 Sidekick / Tracker / Vitara
DTCs may be accessed by installing a jumper wire between diagnostic check connector terminals B and C, located in the RH rear of the engine compartment, then turning the ignition On.
96–00 Sidekick / Tracker / Vitara
Accessing DTCs must be done through the Data Link Connector (DLC), located under the LH side of the instrument panel, using a Suzuki (Tech-1) scan tool or an OBD II generic scan tool.
Reading trouble codes
The instrument panel Check Engine lamp displays the DTCs. In normal operation the lamp will light when the ignition is turned On. However, two different lamp functions can occur when the engine is started. The lamp may turn off immediately, indicating there is no fault at that time, or stay lit, informing the vehicle operator that there is a system failure. If the lamp stays lit a DTC will be stored in the ECM memory. When a DTC is accessed from the ECM memory the Check Engine lamp will flash in a series, indicating the DTC number. When multiple system failures occur applicable DTCs will be indicated three times each. DTCs will continue to flash as long as the ignition is On, and the diagnostic switch terminals are grounded.
Clearing Codes
DTCs may be erased by disconnecting and isolating the battery ground cable for more than 60 seconds, or after 50 key cycles if the malfunction has not recurred.
On models with OBD II, the DTCs may be cleared with the scan tool, following the tool manufacturer’s instructions.
Review Overview
Useful Information
USEFUL
Troubleshooting your Suzuki can be made much easier when you're equipped with the diagnostic trouble codes.
User Rating: 4.32 ( 5 votes)
92–95 SIDEKICK
w/MULTI-POINT FUEL INJ
89–95 SIDEKICK & SAMURAI
w/TBI FUEL INJ
13
HO2S Circuit
14
ECT Sensor Circuit
14
ECT Sensor Circuit
15
ECT Sensor Circuit
15
ECT Sensor Circuit
21
TP Sensor Circuit
21
TP Sensor Circuit
41
Ignition Signal Circuit
22
TP Sensor Circuit
42
Crank Angle Sensor Circuit
23
IAT Sensor Circuit
44
Idle Switch Circuit
24
VSS Circuit
45
Idle Switch Circuit
25
Intake Air Sensor Circuit
51
EGR System & Recirculated Exhaust Gas Temperature Sensor
33
Air Flow Sensor Circuit
53
Ground Circuit
34
54
Fifth Switch Circuit
41
71
Test Switch Circuit
42
CMP Sensor Circuit
44
Idle Switch Circuit
45
Idle Switch Circuit
51
EGR System & REGT Sensor Circuit
52
Fuel Injector
86–95 SWIFT w/TBI FUEL INJ
86–95 SWIFT w/MULTI-POINT FUEL INJ
13
O2S Circuit
13
O2S Circuit
14
ECT Sensor Circuit
14
ECT Sensor Circuit
15
ECT Sensor Circuit
15
ECT Sensor Circuit
21
TP Sensor Circuit Signal Voltage High
21
TP Sensor Circuit
22
TP Sensor Circuit Signal Voltage Low
22
TP Sensor Circuit
23
IAT Sensor Circuit
24
Speed Sensor Circuit
24
VSS Circuit
33
25
IAT Sensor Circuit
34
31
Pressure Sensor Circuit
41
32
42
41
Ignition Fail-Safe Signal Circuit
51
EGR System & Recirculated Exhaust Gas Temperature Sensor Circuit
42
52
Fuel Injector, California
51
ESTEEM
GRAND VITARA & VITARA
P0106
MAP Circuit Performance Problem
P0101
MAF Circuit Performance Problem
P0107
MAP Circuit Voltage Low
P0102
MAF Circuit Voltage Low
P0108
MAP Circuit Voltage High
P0103
MAF Circuit Voltage High
P0111
IAT Circuit Range/Performance Problem
P0111
IAT Sensor Circuit Range/Performance
P0112
IAT Circuit Voltage Low
P0112
P0113
IAT Circuit Voltage High
P0113
P0117
ECT Circuit Voltage Low
P0116
ECT Sensor Circuit Range/Performance
P0118
ECT Circuit Voltage High
P0117
P0121
TP Circuit Range/Performance Problem
P0118
P0122
TP Circuit Voltage Low
P0121
TP Circuit Performance Problem
P0123
TP Circuit Voltage High
P0122
P0125
Insufficient Coolant Temperature For Closed Loop Fuel Control
P0123
P0131
HO2S Circuit Voltage Low Sensor 1
P0125
P0132
HO2S Circuit Voltage High Sensor 1
P0131
HO2S Circuit Voltage Low Bank 1 Sensor 1
P0133
HO2S Circuit Slow Response Sensor 1
P0132
HO2S Circuit Voltage High Bank 1 Sensor 1
P0134
HO2S Circuit No Activity Detected Sensor 1
P0133
HO2S Circuit Slow Response Bank 1 Sensor 1
P0135
HO2S Heater Circuit Malfunction Sensor 1
P0134
HO2S No Activity Bank 1 Sensor 1
P0136
HO2S Circuit Malfunction Sensor 2
P0135
HO2S Heater Circuit Malfunction Bank 1 Sensor 1
P0141
HO2S Heater Circuit Malfunction Sensor 2
P0136
HO2S Circuit Malfunction Bank 1 Sensor 2
P0171
Fuel System Too Lean
P0141
HO2S Heater Circuit Malfunction Bank 1 Sensor 2
P0172
Fuel System Too Rich
P0151
HO2S Circuit Low Voltage Bank 2 Sensor 1
P0300
Random Misfire Detected
P0152
HO2S Heater Circuit High Voltage Bank 2 Sensor 1
P0301–P0304
Misfire Cylinders 1–4
P0153
HO2S Circuit Slow Response Bank 2 Sensor 1
P0335
CKP Sensor Circuit Malfunction
P0154
HO2S No Activity Detected Bank 2 Sensor 1
P0340
CMP Sensor Circuit Malfunction
P0155
HO2S Heater Circuit Malfunction Bank 2 Sensor 1
P0400
EGR Flow Malfunction
P0156
HO2S Circuit Malfunction Bank 2 Sensor 1
P0420
Catalyst System Efficiency Below Threshold
P0161
HO2S Heater Circuit Malfunction Bank 2 Sensor 2
P0440
EVAP System Malfunction
P0171
Fuel System Too Lean (Bank 1)
P0443
EVAP System Purge Control Valve Circuit Malfunction
P0172
Fuel System Too Rich (Bank 1)
P0450
EVAP System Pressure Sensor Malfunction
P0174
Fuel System Too Lean (Bank 2)
P0451
EVAP System Pressure Sensor Performance
P0175
Fuel System Too Rich (Bank 2)
P0455
EVAP System Leak Detected (Gross Leak)
P0300
P0461
Fuel Level Sensor Circuit Performance Problem
P0301–P0306
Misfire Cylinders 1–6
P0463
Fuel Level Sensor Circuit Voltage High
P0335
P0480
Radiator Cooling Fan Control System Malfunction
P0340
P0500
VSS Malfunction
P0400
P0505
ISC System Malfunction
P0420
Catalyst System Efficiency Below Threshold (Bank 1)
P0506
ISC System RPM Lower Than Expected
P0430
Catalyst System Efficiency Below Threshold (Bank 2)
P0507
ISC System RPM Higher Than Expected
P0440
EVAP II System Malfunction
P0510
CTP Switch Malfunction
P0450
EVAP II System Pressure Sensor Malfunction
P0601
Internal Control Module Memory Checksum Error
P0451
EVAP Pressure Sensor Range/Performance
P0603
Internal Control Module KAM Error
P0455
EVAP Gross Leak Detected
P0705
Transaxle Range Sensor Switch Circuit Malfunction
P0461
P0715
Input Speed Sensor Circuit Malfunction
P0463
P0720
Output Speed Sensor Circuit Malfunction
P0500
VSS Malfunction
P0725
Engine Speed Input Circuit Malfunction
P0505
IAC System Malfunction
P0741
TCC Solenoid Performance Or Stuck Off
P0601
P0743
TCC Solenoid Electrical
P1408
MDP Sensor Circuit Malfunction
P0745
Pressure Control Solenoid Malfunction
P1410
EVAP II Fuel Tank Pressure Control System Malfunction
P0751
Shift Solenoid ‘‘A’’ (No. 1) Performance Or Stuck Off
P1450
BARO Sensor Circuit Malfunction
P0753
Shift Solenoid ‘‘A’’ (No. 1) Electrical
P1451
BARO Circuit Performance Problem
P0756
Shift Solenoid ‘‘B’’ (No. 2) Performance Or Stuck Off
P1500
Engine Starter Signal Circuit Malfunction
P0758
Shift Solenoid ‘‘B’’ (No. 2) Electrical
P1510
ECM Back-Up Power Supply Malfunction
P1410
P1450
BARO Sensor Voltage High/Low
P1451
BARO Sensor Performance Problem
P1460
P1500
P1510
P1530
Ignition Timing Adjustment Switch Circuit Malfunction
P1600
Serial Communication Problem Between ECM & TCM
P1700
TP Signal Input Malfunction
P1705
ECT Signal Input Malfunction
P1717
A/T Drive Range Signal Circuit Malfunction
P1895
TCM To ECM Torque Reduction Circuit Malfunction
96–98 SIDEKICK & X-90 1.6L ENGINE
96–98 SIDEKICK 1.8L ENGINE
P0101
P0101
P0102
P0102
P0103
P0103
MAF Voltage High
P0112
P0111
P0113
P0112
P0117
P0113
P0118
P0117
P0121
P0118
P0122
P0121
TP Sensor Circuit Performance Problem
P0123
P0122
TP Sensor Circuit Voltage Low
P0125
P0123
TP Sensor Voltage High
P0131
P0125
P0132
P0131
HO2S 1 Circuit Voltage Low
P0133
P0132
HO2S 1 Circuit Voltage High
P0134
HO2S No Activity
P0133
HO2S 1 Circuit Slow Response
P0135
P0134
HO2S 1 Circuit No Activity
P0136
P0135
HO2S 1 Heater Circuit Malfunction
P0141
P0136
HO2S 2 Circuit Malfunction
P0171
P0141
P0172
P0171
P0300
P0172
P0301–P0304
P0300
Random Misfire
P0335
P0301–P0304
P0340
P0335
P0400
P0340
P0420
P0400
P0440
P0420
P0443
EVAP I System Improper Purge Flow
P0440
P0450
P0443
EVAP System Improper Purge Flow
P0461
P0450
EVAP Pressure Sensor Malfunction
P0463
P0451
P0500
VSS Malfunction
P0455
EVAP Leak Detected (Gross Leak)
P0505
P0461
P0510
P0463
P0601
P0500
VSS Malfunction
P0603
P0505
P0705 (34)
Transmission Range Switch Circuit Malfunction
P0601
P0720 (31)
OSS Malfunction
P0603
P0725 (52)
P0705 (34)
P0741 (29)
P0720 (31)
OSS Circuit Malfunction
P0743 (25 Or 26)
TCC Lock-Up Solenoid Electrical
P0725 (52)
P0751 (27)
P0741 (29)
TCC Lock-Up Solenoid Performance Or Stuck Off
P0753 (21 Or 22)
P0743 (25 Or 26)
P0756 (28)
P0751 (27)
P0758 (23 Or 24)
P0753 (21 Or 22)
P0771 (29)
P0756 (28)
P0773 (25 Or 26)
P0758 (23 Or 24)
P1408
P0771 (29)
P1410
P0773 (25 Or 26)
P1450
P1408
P1451
P1410
P1500
P1450
P1510
P1451
BARO Sensor Circuit Performance Problem
P1530
P1500
P1600
P1510
P1700 (32 Or 33)
P1530
P1705 (34)
P1600
P1710
Back-Up Signal For Speed Sensor Circuit Malfunction
P1700 (32 Or 33)
P1715
PNP Switch Circuit Malfunction
P1705 (51)
P1875
4WD Low Switch Circuit Malfunction
P1710 (35)
P1875 (37)
96–00 SWIFT
P0106
P0107
P0108
P0111
P0112
P0113
P0116
Engine Coolant Temperature Circuit Range/Performance Problem
P0117
P0118
P0121
TP Sensor Circuit Range/Performance Problem
P0122
P0123
TP Sensor Circuit Voltage High
P0125
P0131
P0132
P0133
P0134
HO2S 1 Circuit No Activity Detected
P0135
P0136
P0141
HO2S 2 Heater Circuit Malfunction
P0171
P0172
P0300
Misfire Detected
P0301–P0304
P0335
P0340
P0400
P0420
P0440
EVAP System Malfunction/Gross Leak Detected
P0443
P0450
P0451
P0455
EVAP System Malfunction, Large Leak Detected
P0461
P0463
P0480
Radiator Fan Control System Malfunction
P0500
VSS Malfunction
P0505
P0506
P0507
P0510
P0601
P0603
P0705
Transmission Range Sensor Circuit Malfunction (A/T)
P0720
OSS Circuit Malfunction (A/T)
P0751
Shift Solenoid ‘‘A’’ (No. 1) Performance Or Stuck Open
P0753
Shift Solenoid ‘‘A’’ (No. 1) Electrical (A/T)
P0756
Shift Solenoid ‘‘B’’ (No. 2) Performance Or Stuck Open
P0758
Shift Solenoid ‘‘B’’ (No. 2) Electrical (A/T)
P1250
EFE Heater Circuit Malfunction
P1410
P1450
P1451
P1460
P1500
P1510
P1530
Check Also
ZUKIWORLD Fall Classic explores the Ochoco National Forest
PRINEVILLE, OR – We have been holding the Fall Classic adventure event for over 20+ …
2 comments
  1. Good afternoon ladies and gentlemen
    I have a problem with an Suzuki grand Vitara diesel from 2011 . I have one single DCT B 1705
    The problem is
    I am in Africa and here is no Suzuki dealership around or that one I have found/ dealer is not willing to work on the car because It was not brought by him what is here very common .
    I am looking for a solution for that problem. B 1705
    I have an autel 808 as diagnosis tool. The engine turns over . I can see the fuel pressure on live Data but the engine is not starting. This is a immobilizer transponder issue I strongly believe
  2. Hey. I just purchased a 1997 suzuki sidekick, 4 cyclinder, 1.6 liter/ 16 valve/ 4door / jx. Should I have a 16 pin DTC plug under the left side of the dash? ( which should be a OBT 2 plug)? Or should I have a 4 or 6 pin plug on the left hand side of the dash ( which I think would be a OBD 1 plug) ? Actually I have a square that looks like a 6 pin DTC plug under the left side of the dash. I have a OBD 2 scanner that is the 16 pin connector . So would I have to get a adapter that adaptes from a 16 pin to a 6 pin to use my OBD 2 scanner to scan OBD 1? I am so confused at this point. Everywhere I read it tells me that I should have a OBD 2 plug because my Suzuki is a 1997. Any help would be greatly appreciated. Thanks for your time. John
Leave a Reply
Your email address will not be published. Required fields are marked *
This site uses Akismet to reduce spam. Learn how your comment data is processed.
