SUZUKI SIDEKICK – MODIFICATION OF INTAKE MANIFOLD – TSB
   DOCUMENT TYPE: Technical Service Bulletin
   SUBJECT: Modification of Intake Manifold and Thermostat
   SOURCE OF FILE OR DOCUMENT: Unknown
suzuki_underline_650
This bulletin is to inform you of the modification in the intake manifold and thermostat which has been carried out in the 2-door (June 1992 & later) and 4-door 16-valve (December 1991 & later) Sidekicks. The thermostat mounting surface and port on the intake manifold have been enlarged in diameter to accommodate a thermostat with a rubber 0-ring. Since the late-style rubber 0-ring is not interchange-able with the early-style manifold, use the late-style rubber 0-ring with the late-style manifold.
CLICK HERE TO DOWNLOAD
[pdf-embedder url=”https://www2.zukiworld.com/wp-content/uploads/2018/09/16v-STAT-bung1.pdf” title=”TS 4-13 04063(R)”]
Check Also
ZUKIWORLD Fall Classic explores the Ochoco National Forest
PRINEVILLE, OR – We have been holding the Fall Classic adventure event for over 20+ …
Leave a Reply
Your email address will not be published. Required fields are marked *
This site uses Akismet to reduce spam. Learn how your comment data is processed.
