ZUKIWORLD online’s
Vitara -Introduced in 1999 Available in 2 and 4-door hard and softtop models. economically fitted with a 2.0 liter I-4 engine. GENERAL Vehicle Type Two-Door, Soft Top EPA Vehicle Class Sport-Utility Powertrain Layout (2WD) Front Engine, Rear-Wheel Drive (4WD) Front Engine, Rear/Four-Wheel Drive Body Structure Ladder Frame with Boxed Rails Body Material Steel, Body-on-Frame Seating Capacity Four SUSPENSION Front Independent MacPherson Strut, coil springs, stabilizer bar Rear Five-Link Coil Spring, Solid Axle STEERING Type Power Assisted Rack-and-Pinion Ratio 20.5:1 Turning Diameter, Curb-to-Curb 31.5 ft. (9.9m) Turning Radius 15.8 ft. (5.0m) Number of wheel turns stop to stop (power) 3.8 BRAKES Type Power / Hydraulic Front Ventilated Disc Rear Drum Parking Brake Lever-hand operated WHEELS AND TIRES Wheel Type Steel or Aluminum Alloy Wheel Size 15 in.(1.6L) / 16 in. (2.0L) Tire Type All-Season, Steel-Belted Radial Tire Size 195/75R15 (1.6L 2WD) 205/75R15 (1.6L 4WD) 215/65R16 (2.0L) Spare Size Full-Size RESTRAINT SYSTEM Airbags Driver and Front Passenger Safety Belts Three-Point Front and Rear ENGINE Type 1.6 Liter, 16-Valve, SOHC 2.0 Liter, 16-valve, DOHC Block Material Aluminum Alloy Aluminum Alloy Induction System Multi-point Electronic Fuel Injection MPFI Displacement 97 cu. in. 122 cu. in. Horsepower (SAE net) 97 hp @ 5,200 rpm 127 hp @ 6,000 rpm Torque (SAE net) 103 lb.-ft. @ 4,000 rpm 134 lb.-ft. @ 3,000 rpm Bore x Stroke 2.95 in. x 3.54 in. 3.31 X 3.54 Compression Ratio 9.5:1 9.7:1 DRIVETRAIN (Manual Transmission) Transmission Type Five-Speed, Synchronized Clutch Type Disc Gear Ratios: 1.6 Liter 2.0 Liter 1st 3.652 3.652 2nd 1.947 1.947 3rd 1.379 1.379 4th 1.000 1.000 5th 0.795 0.777 Reverse 3.670 3.670 Transfer gear ratios Low (4WD) 1.816 1.816 High 1.000 1.000 Differential Ratio 4.875 4.875 DRIVETRAIN (Automatic Transmission) Transmission Type Four-Speed with Overdrive Torque Converter Lock-Up Gear Ratios: 1.6 Liter 2.0 Liter 1st 2.826 2.826 2nd 1.493 1.493 3rd 1.000 1.000 4th 0.730 0.689 Reverse 2.703 2.703 Transfer gear ratios Low (4WD) 1.816 1.816 High 1.000 1.000 Differential Ratio 5.125 5.125 CAPACITIES 1.6 Liter 2.0 Liter Engine Oil 4.2 U.S. qts. (4.0L) 5.2 U.S. qts. (5.0L) Fuel Tank 14.8 U.S. gal. (56L) Engine Coolant 5.7 U.S. qts. (5.5L) 6.8 U.S. qts. (6.5L) AutomaticTransmission Fluid 7.3 U.S. qts. (6.9L) 7.5 U.S. qts. (7.1L) Transmission Oil Manual (2WD) 2.0 U.S. qts. (1.9L) Manual (4WD) 1.6 U.S. qts. (1.5L) Differential Gear Oil Front 1.1 U.S. qts. (1.0L) Rear 2.3 U.S. qts. (2.2L) Transfer Gear Box Oil 1.8 U.S. qts. (1.7L) Towing 1000 lb EXTERIOR DIMENSIONS Wheelbase 86.6 in. Tread Width Front 57.5 in. Rear 57.5 in. Overall Width (Body) 67.5 in. Overall Length 150.2 in. Overall Height 66.3 in. (1.6L) 66.5 (2.0L) Minimum Running Ground Clearance 7.7 in. Approach Angle 1.6L 29.8o (2WD) 31.5o (4WD) 2.0L 31o (2WD) 32o (4WD) Departure Angle 1.6L 26.5o (2WD) 28o (4WD) 2.0L 27.4o (2WD) 28.3o (4WD) INTERIOR DIMENSIONS Headroom (front/rear) 40.9 / 39.5 in. Legroom (front/rear) 41.4 / 35.9 in. Shoulder Room (front/rear) 53.0 / 52.6 in. Hip Room (front/rear) 50.6 / 46.8 in. Rear Cargo Length 36.6 in. Width 42.5 in. Height 37.2 in. EPA Cargo Index (Rear Seat Up/Down) 9.9/33.7 cu. ft. Interior Volume 96.8 cu.ft. WEIGHTS JS JX Curb Weight (2WD) (4WD) Automatic 2635 lbs. (1.6L) 2723lbs. (2.0L) 2756 lbs. (1.6L) 2844 lbs. (2.0L) Manual 2601 lbs. (1.6L) 2690 lbs.(2.0L) 2723 lbs. (1.6L) 2811 lbs. (2.0L) Gross Vehicle Weight 3373 lbs. (1.6L) 3483 lbs.(2.0L) 3483 lbs. (1.6L) 3593 lbs.(2.0L) Gross Axle Weight Front 1499 lbs. (1.6L) 1587 lbs.(2.0L) 1587 lbs. (1.6L) 1675 lbs. (2.0L) Rear 2028 lbs. (1.6L) 2050 lbs.(2.0L) 2050 lbs. (1.6L) 2072 lbs.(2.0L) EPA FUEL ECONOMY ESTIMATES JS JX Manual (City / Highway) 25/28 (1.6L) 22/24 (2.0L) 25/27 (1.6L) 22/24 (2.0L) Automatic (City / Highway) 25/27 (1.6L) 23/25 (2.0L) 24/27 (1.6L) 23/25 (2.0L) Estimated Highway Range (5 spd. manual) 414.4/355.2 399.6/355.2
Looking for leads on a manual transmission for 2000 vitara jls. I’m coming up with nothing. Even a rebuild kit. Tia
Call Trail Tough Suzuki. they should be able to help you.
