BUDGET LIFT – Lifting a Sidekick Using Grand Vitara Coils
BUDGET LIFT
Editor: Eric Bewley Story/Photo: Jeff Johnson, Tim Walters
NICHOLSON, PA -Difficult times have left me without my trusted Samurai and in need of a capable vehicle able to pre-run and be a part of GONZOOKIN and event that I have been extensively involved with since it’s inception in 2000. This event has grown so much and has become a significant and enjoyable part of my life. Now that I didn’t have a zook capable of running trails any harder than a dirt road, how would I be able to work the event in a stocker? This question lead me to ask my friends for a little assistance.
kicklift 13.jpg (27286 bytes)
A good friend of mine and co-founder and coordinator of GONZOOKIN called me up and had a great idea.  Tim Walters, AKA Yankee Tim, had been doing some research and believed that using stock Grand Vitara springs on a Sidekick might lift it similar to the Old Man Emu springs. So after a few conversations and a quick drive up to Tim’s house, we installed the springs. To say the least, the results were amazing. Using the Grand Vitara springs yielded a two inch lift measured and compared at the frame height.   An interesting side note we discovered is that the stock struts and shocks on the GV were identical so they would not help travel any.
click to enlarge
click to enlarge
For the rear, we used the rear springs on a 92-02 Ford Econoline E150 van. These springs are 2 inches longer and have an additional 1.5 “ of travel.  The mounting of the springs from the sidekick and ford shocks and they are identical.  To gain extra front travel, we flipped the strut blate to add an additional inch of length.
The springs did cause the caster to be out so an alignment has been scheduled done to fix this.
click to enlarge click to enlarge click to enlarge
Check Also
ZUKIWORLD Fall Classic explores the Ochoco National Forest
PRINEVILLE, OR – We have been holding the Fall Classic adventure event for over 20+ …
5 comments
  1. I’m confused. What coil springs are used in the rear then? I’m reading this as saying GV coils up front, E150 shocks in the rear, rear coils are???
  2. So, let me get this straight. You used Grand Vitara coils on both front and rear. Correct? If so, from what rear and model of Grand Vitara, 2wd/4wd, engine type 4 or v-6. The rear shocks I get Ford van shocks. Thanks
  3. How is the ride with this modification?
  4. For the How to Sidekick budget lift article. Ford E vans all have leaf springs in the rear suspensions. Does the writer mean front coil springs from the E150?
    • No i believe he meant rear Shock absorbers from the E-150 Vans… as you need a 2″ longer shock, you can also use a 2×2 square tube to extend the stock shock
Leave a Reply
Your email address will not be published. Required fields are marked *
This site uses Akismet to reduce spam. Learn how your comment data is processed.
