Review Overview
Fit & Finish
Engineered Quality
Ease of Installation
SAS Kit
S.O.R.D. - has created a great kit that allows builders a solid alternative to the solid axle swap for the Sidekick/Tracker. A key component of this build.
Suzuki Sidekick Solid Axle Swap with 35″ tires and more!
Part one…
Editor: E. Bewley
Salem, OR – The time came when our family had grown to the size that our Samurai and even our 2-door Sidekick just didn’t have enough room for long trips. Adding a child’s safety seat and the associated gear that a kid needs to be ‘happy’ on the trail can easily stuff a vehicle in about 5 seconds flat. Before our first child came, I had been bouncing the idea of building a 4-door just have more room for long distance overland expeditions where we would be out for weeks at a time and sometimes, the distance between services would make traveling in a 2-door difficult. In a chance conversation with Sky from Sky’s Off-Road Design the idea of building a kick using all of the components one had already invested in and built in a Samurai with took shape. Simply put, you build a radically cool Samurai and then a family comes and you have no room. Do you sell your Samurai with all the goodies or do you transfer them over? We chose to transfer…
This project starts off with an exceptionally clean ’94 4-door JX. A JLX would have been a bit nicer but we wanted a manual transmission and it’s quite difficult to find a JLX with a manual. So, we’ll swap in the couple of goodies we wanted such as cruise control and the softer/better interior bits. Next step, this one was easy for us… We just dropped off the stock Sidekick to Sky’s shop and said, “Have fun” and they did. The kit was designed on this chassis but you couldn’t tell it as the fit and finish is great and if you’re thinking of doing a leaf sprung solid axle swap, definitely check this one out.
But this build is more than just a suspension kit. Sky also provided a set of custom axle housings including an offset rear to help with driveline angles as we’re going to use a Samurai t-case. SORD’s custom axle housings are really cool and they provide a solid foundation for this project. Did I mention they’re cool?
Below are a few glamour shots of the initial part of the build done at SORD’s shop. After this part of the build, we sent it to 99W for body and paint and now it’s back to our shop to finish the drive train, add armor, and fill it up with all the trail goodies we think we’ll need. Here’s a build overview:
1994 Sidekick Project Plus One
- SORD Leaf sprung Solid Axle Swap
- SORD Front and Rear custom Axles (Toyota Based)
- 99W Body & Paint with customized fenders for more room
- Samurai t-case w/crawler gears (from donor Samurai)
- Tom Wood’s drivelines (from donor Samurai)
- Front & Rear bumpers Used Calmini bumpers
- WARN winch (from donor Samurai)
- Custom build rocker skids & roof rack
- Adventure goodies (lights, sand ladders, fuel cans, etc…)
what size leaf spring did you use and what is you travel or articulation
I sent an email to Sky and here’s his response to my asking him the cost of doing the conversion. I also assumed it was a recent build and it’s not.
That was actually about 4 years ago, its just now getting a review lol. We only sell the brackets for the kit at this point, they run $800
Sky.
The length of time for the ‘review’ is our fault and has nothing to do with Sky’s product or service, which is great!
Eric do you know what gear ratio was used in the diff’s and transfer case ?
Ed
Hi Ed – Haven’t done the thirds & gears yet but my plan is to do 5.29 and a 5.8:1 t-case. I’m going to spin that engine!
3.65 x 5.8 x 5.29 = 111.98 to 1 crawl ratio ! very nice !
Cost ? Im looking to do the same to a 4 dr kick I have…
I don’t have a price point on this. I’m assuming you mean the solid axle swap kit from Sky… I’d suggest giving them a call and ask them. I’ll also ask
