Project TRICKER-KICKER
Calminis 6″ Combo Lift Kit, Theres More Then Just Clearance To Gain. -Junior
Continued. Next unbolt the gas tanks filler hose from the body. Cutting and extending of the filler hose and replacement of the vent tube is require. Calmini provides the necessary hardware for this.
Gas tank Filler hose
W/extension added
e-brake cable
Here were loosening the emergency brake cables. Dont forget to properly adjust before test-driving.
Were almost ready to lift the car. Using Calminis instructions, identify the steering column in your application. In our case we decided to add power steering and opted to install a later models steering column. We acquired that steering column from the power steering donor vehicle. This eliminated our need to extend the existing steering column. Now its time to lift the vehicle.
Once the body has been lifted enough to install the required hardware, begin placing each body mount in its receptive locating. Using the 2″ square tube and 1″ machined aluminum pucks we placed them in the shown configuration. This is repeated six times. Calmini provides new hardware so be sure to use it.
Forward mount
Mid mount
Rear Mount
For purchase information on this lift and many other fine CALMINI product, visit them at: www.calmini.com
**PIC 0209**
The front mount uses the larger black fiber blocks as shown. Note the triangular hole we had to cut in the frames body mount base. This gave us access to the stock, and rusted, nuts welded to the inside of this chamber. It may not be necessary for you to have to do this. Ours were so bad the welds let go when we tightened the bolts.
Heres what it looks like with 32s and just a body lift.
