TECH LIBRARY – FREE DOWNLOADS
Review Overview
Easy to Download
Useful once downloaded
Will come back again
Helpful
Downloadable Documentation was helpful to me!
User Rating: 4.01 ( 12 votes)
RESEARCH – Downloadable documents for your Suzuki
FSM (Factory Service Manuals), USR (User Created Documents), OWN (Owner’s Manual), TSB (Technical Service Bulletin), Sales Brochures, etc.. Files from all over the ‘net with credit given when known. Please contact us if you have a file you’d like to add that may help the Suzuki automotive community. In addition to the list below we have begun to back up other technical documents as Posts. So, also check and search our regular section for more information.
suzuki_underline_650
ThumbNameSize
Thumb USR-Swift-GT-Gauge-Cluster-Wiring.jpg no/mime
Open Download Copy Link 84.65 KB April 17, 2014
84.65 KB
Thumb FSM-Samurai-Fuel-Injection-Supplement-Manual-rhinoman-99501-83350-33E.pdf no/mime
Open Download Copy Link 158.16 MB April 28, 2014
158.16 MB
Thumb FSM-Samurai-Maintenance-Manual-99500-83300-33E.pdf no/mime
Open Download Copy Link 266.4 MB April 17, 2014
266.4 MB
Thumb FSM-Sidekick-1996-Air-Conditioning.pdf no/mime
Open Download Copy Link 1.94 MB April 17, 2014
1.94 MB
Thumb FSM-Sidekick-Vitara-Service-Manual-rhinoman-99500-60A10-01E.pdf no/mime
Open Download Copy Link 27.74 MB April 28, 2014
27.74 MB
Thumb FSM-Swift-Electrical-Component-Locator-1_3L-TBI.pdf no/mime
Open Download Copy Link 68.12 KB April 17, 2014
68.12 KB
Thumb FSM-Swift-GT-ECM-Electrical.pdf no/mime
Open Download Copy Link 171.51 KB April 17, 2014
171.51 KB
Thumb FSM-Swift-GT-G13B-Cam-Timing.pdf no/mime
Open Download Copy Link 63.63 KB April 17, 2014
63.63 KB
Thumb FSM-Swift-GT-G13B-TPS-Adjustment.pdf no/mime
Open Download Copy Link 120.86 KB April 17, 2014
120.86 KB
Thumb FSM-Swift-GT-ISC-Solenoid-Valve.pdf no/mime
Open Download Copy Link 85.41 KB April 17, 2014
85.41 KB
Thumb FSM-Swift-GT-Ignition-System.pdf no/mime
Open Download Copy Link 20.87 KB April 17, 2014
20.87 KB
Thumb FSM-Swift-GT-Junction-Fuse-Block.pdf no/mime
Open Download Copy Link 81.19 KB April 17, 2014
81.19 KB
Thumb FSM-Swift-GT-Manual-Transmission-Schematic.pdf no/mime
Open Download Copy Link 221.47 KB April 17, 2014
221.47 KB
Thumb FSM-Swift-Supplimental-Four-Wheel-Drive-99501-71C00-01E.pdf no/mime
Open Download Copy Link 15.46 MB April 17, 2014
15.46 MB
Thumb FSM-Vitara-1999-2005-Chassis-Electrical-Body-Manual-.pdf no/mime
Open Download Copy Link 20.18 MB April 17, 2014
20.18 MB
Thumb FSM-Vitara-1999-2005-Engine-Drivetrain-Manual.pdf no/mime
Open Download Copy Link 7.96 MB April 17, 2014
7.96 MB
Thumb FSM-Vitara-1999-2005-Full-Service-Manual.pdf no/mime
Open Download Copy Link 12.15 MB April 17, 2014
12.15 MB
Thumb FSM-Vitara-1999-2005-Service-Manual-Canvas-Top-Supplemental.pdf no/mime
Open Download Copy Link 1.92 MB April 17, 2014
1.92 MB
Thumb FSM-Vitara-1999-2005-Transmission-Transfer-Case-Differential-Manual-.pdf no/mime
Open Download Copy Link 5.97 MB April 17, 2014
5.97 MB
Thumb OWN-Tracker-Owners-Manual-1998.pdf no/mime
Open Download Copy Link 20.38 MB April 17, 2014
20.38 MB
Thumb TSB-AC-Compresor-Refrigerant-Oil-Checking.pdf no/mime
Open Download Copy Link 48.1 KB April 17, 2014
48.1 KB
Thumb TSB-AC-Compresor-Servicing.pdf no/mime
Open Download Copy Link 68.92 KB April 17, 2014
68.92 KB
Thumb TSB-AC-Compresor-and-Magnetic-Clutch-Assembly.pdf no/mime
Open Download Copy Link 505.66 KB April 17, 2014
505.66 KB
Thumb TSB-AC-System-General-Servicing.pdf no/mime
Open Download Copy Link 85.36 KB April 17, 2014
85.36 KB
Thumb TSB-AC-System-Specifications.pdf no/mime
Open Download Copy Link 46.02 KB April 17, 2014
46.02 KB
Thumb TSB-AT-Transmission-Controler-Change-Bulletin.pdf no/mime
Open Download Copy Link 69.56 KB April 17, 2014
69.56 KB
Thumb TSB-Alternators-and-Regulators.pdf no/mime
Open Download Copy Link 116.63 KB April 17, 2014
116.63 KB
Thumb TSB-Battery-Maintenance.pdf no/mime
Open Download Copy Link 71.1 KB April 17, 2014
71.1 KB
Thumb TSB-Brake-System.pdf no/mime
Open Download Copy Link 114.23 KB April 17, 2014
114.23 KB
Thumb TSB-Clutch-and-Compresor-Asembly.pdf no/mime
Open Download Copy Link 69.02 KB April 17, 2014
69.02 KB
Thumb TSB-Drive-Axles.pdf no/mime
Open Download Copy Link 99.03 KB April 17, 2014
99.03 KB
Thumb TSB-Engine-1_6L-Diagnostics.pdf no/mime
Open Download Copy Link 258.15 KB April 17, 2014
258.15 KB
Thumb TSB-Engine-Cooling.pdf no/mime
Open Download Copy Link 82.33 KB April 17, 2014
82.33 KB
Thumb TSB-Fuses-and-Circuit-Breakers.pdf no/mime
Open Download Copy Link 55.23 KB April 17, 2014
55.23 KB
Thumb TSB-High-Tension-Wire-Bulletin.pdf no/mime
Open Download Copy Link 58.3 KB April 17, 2014
58.3 KB
Thumb TSB-Hood-Fly-Up-Bulletin.pdf no/mime
Open Download Copy Link 121.92 KB April 17, 2014
121.92 KB
Thumb TSB-Idle-Adjust.pdf no/mime
Open Download Copy Link 158.76 KB April 17, 2014
158.76 KB
Thumb TSB-Idle-Speed-Isc-Duty-Adjustement.pdf no/mime
Open Download Copy Link 63.42 KB April 17, 2014
63.42 KB
Thumb TSB-Instrument-Panel.pdf no/mime
Open Download Copy Link 107.98 KB April 17, 2014
107.98 KB
Thumb TSB-Modification-Of-The-ECM-Module.pdf no/mime
Open Download Copy Link 65.79 KB April 17, 2014
65.79 KB
Thumb TSB-Starter.pdf no/mime
Open Download Copy Link 152.83 KB April 17, 2014
152.83 KB
Thumb TSB-Swift-G13B-Engine-Adjustments.pdf no/mime
158.76 KB
Thumb TSB-Swift-GT-General-Specs-1-of-2.pdf no/mime
Open Download Copy Link 62.86 KB May 15, 2021
62.86 KB
Thumb TSB-Swift-GT-General-Specs-2-of-2.pdf no/mime
158.76 KB
Thumb TSB-Swift-GT-Wiring-Diagrams.pdf no/mime
Open Download Copy Link 600.41 KB April 17, 2014
600.41 KB
Thumb TSB-Swift-MK3-Instrument-Panel-Testing.pdf no/mime
107.98 KB
Thumb TSB-Swift-Wiring-Diagrams.pdf no/mime
600.41 KB
Thumb USR-Samurai-Usefull-Random-Parts-Catalog.pdf no/mime
Open Download Copy Link 887.28 KB April 17, 2014
887.28 KB
Thumb Simple-File-List.pdf no/mime
Open Download Copy Link 1.11 MB November 16, 2020
1.11 MB
Thumb FSM-1986-to-1988-Suzuki-Samurai-Service-Manual.pdf no/mime
Open Download Copy Link 266.4 MB September 20, 2020
266.4 MB
Thumb FSM-2006-to-2011-Suzuki-Grand-Vitara-FSM.pdf no/mime
Open Download Copy Link 84.59 MB May 23, 2021
84.59 MB
Thumb FSM-1986-1988_SuzukiSamurai_manual_transmission_manual.pdf no/mime
Open Download Copy Link 52.8 MB September 20, 2020
52.8 MB
Thumb FSM-1998-to-2017-SN413-Jimny-fsm.pdf no/mime
Open Download Copy Link 25.49 MB September 20, 2020
25.49 MB
Thumb FSM-1986-1988_SuzukiSamurai_engine_manual.pdf no/mime
Open Download Copy Link 38.97 MB September 20, 2020
38.97 MB
Thumb FSM-1986-1988_SuzukiSamurai_emissions_manual.pdf no/mime
Open Download Copy Link 29.09 MB September 20, 2020
29.09 MB
Thumb FSM-1986-1988_SuzukiSamurai_transfercase_manual.pdf no/mime
Open Download Copy Link 6.22 MB September 20, 2020
6.22 MB
Thumb FSM-1986-1988_SuzukiSamurai_ignition_manual.pdf no/mime
Open Download Copy Link 7.45 MB September 20, 2020
7.45 MB
Thumb FSM-1986-1988_SuzukiSamurai_Troubleshooting_Manual.pdf no/mime
Open Download Copy Link 757.99 KB September 20, 2020
757.99 KB
Thumb FSM-1986-1988_SuzukiSamurai_suspension_manual.pdf no/mime
Open Download Copy Link 7.24 MB September 20, 2020
7.24 MB
Thumb FSM-1986-1988_SuzukiSamurai_service_data.pdf no/mime
Open Download Copy Link 3.36 MB September 20, 2020
3.36 MB
Thumb FSM-1986-1988_SuzukiSamurai_body_electrical.pdf no/mime
Open Download Copy Link 2.99 MB September 20, 2020
2.99 MB
Thumb FSM-1986-1988_SukzukiSamurai_charging_system.pdf no/mime
Open Download Copy Link 4.32 MB September 20, 2020
4.32 MB
Thumb FSM-1986-1988_SuzukiSamurai_electrical_diagram.pdf no/mime
Open Download Copy Link 4.68 MB September 20, 2020
4.68 MB
Thumb FSM-1986-1988_SuzukiSamurai_cranking_system_manual.pdf no/mime
Open Download Copy Link 5.89 MB September 20, 2020
5.89 MB
Thumb FSM-1986-1988_SuzukiSamurai_differential_manual.pdf no/mime
Open Download Copy Link 3.39 MB September 20, 2020
3.39 MB
Thumb FSM-1986-1988_SuzukiSamurai_clutch_manual.pdf no/mime
Open Download Copy Link 6.57 MB September 20, 2020
6.57 MB
Thumb FSM-1986-1988_SuzukiSamurai_chassis_dimension.pdf no/mime
Open Download Copy Link 664.45 KB May 15, 2021
664.45 KB
67
22 comments
  1. James Christopher Ard
    I need any service manual for 95 sidekick especially wiring and engine diagnostics
  2. i have a 79 suzuki forsa, but cant find a repair manual. is there any help out there for me
  3. I do not see anything that I could download for my 1999 Suzuki Vitara (not Grand).
    The TECH LIBRARY – FREE DOWNLOADS block is empty except for [eeSFL showdate=”NO”]
  4. Where’s the tech library – free downloads? The page is here but there’s no tech library?
  5. Michael Taliangis
    Does anyone have a photo of the fuse box cover for a SJ50 as mine is missing and am not sure what fuses are required where and for what ? There seems to be a lot of empty slots !!!!! Any help would be appreciated!!!
  6. Hello, I have a 1988.5 Samurai. Is there a service manual specific to this year? Awesome publications. Thanks!
  7. Thanks for providing all of these Suzuki publications and downloads at no cost and no trick downloaders, links or viruses. 👍
  8. I have a 1997 Suzuki sidekick 1.6 liter/16 valve/ JX 4 door. I am trying to figure out how my check engine light does not work. With ignition on not running or engine running the light does not come on
  9. looking for a FSM for a 1994 samurai. I see a 86-87 one on the site.
  10. ok ….every good
  11. looking for a FSM for 1995 sidekick.
    Is it available for download?
    • I believe we now have what you’re looking for above… If not, check back soon as well be uploading and updating this more often since we got the software working.
  12. I need to do a complete engine rebuild on my 2002 tracker with the H25A 2.5L V6 engine vin code 4 . I have had no luck finding a manual covering the engine. I can build the engine without it but I really need specs for torque and settings, timing, etc. Any help will be greatly appreciated.
  13. Still no tech downloads
  14. There doesn’t appear to be anything under tech downloads – at least not showing up on my computer
  15. I have to rebuild the engine
    And need specific pound ft values
Leave a Reply
Your email address will not be published. Required fields are marked *
This site uses Akismet to reduce spam. Learn how your comment data is processed.
